Need sidecar mounts for Goldwing GL1200 / Escort rig
xs1100sgman
Posted 8/19/2012 10:55 PM (#66336)
Subject: Need sidecar mounts for Goldwing GL1200 / Escort rig
25
I am in need of some sidecar mounts to connect an Escort sidecar to a 1984 Goldwing GL1200. I have a set of universal sidecar mounts that I used on another bike that I would be willing to trade if necessary. Any help is appreciated.
xs1100sgman
Posted 8/26/2012 9:09 PM (#66495 - in reply to #66336)
Subject: RE: Need sidecar mounts for Goldwing GL1200 / Escort rig
25
It looks like the only issue will be the bottom rear mount. There  may be a modification needed to the floorboard mount to attach the bottom rear mount. I am still open to suggestions. Anyone?
 Regards,
 Les
(photo.JPG)
Attachments photo.JPG (90KB - 1 downloads)
Barry
Posted 8/26/2012 9:26 PM (#66496 - in reply to #66336)
Look at this
http://www.motorvation.com/gl12mts1.htm
xs1100sgman
Posted 8/26/2012 9:36 PM (#66497 - in reply to #66496)
25
Thanks Barry, I have been looking at those photos for the last few days, I just don't have the machinery or tools to make it happen other than drilling that hole in the floorboard mount. I'm sure that sidecar mount exists I just need to find it.
Barry
Posted 8/26/2012 9:47 PM (#66498 - in reply to #66336)
Subject: Re: Need sidecar mounts for Goldwing GL1200 / Escort rig
You can buy those mounts from motorvation. Look around their web site and you will find a price list. Motorvation uses eye nuts and Champion use heim joints so I'm not sure if they can sell you anything. I would assume tomorrow DMC or Lonnie will respond with ideas.
Edited by Barry 8/26/2012 10:05 PM
jaydmc
Posted 8/27/2012 2:09 PM (#66526 - in reply to #66498)
100050010025
We have every thing you will need for this.
The bike side mounts run $675
Unlike most other mounts for your bike on the market, Our mounts do not place the lower rear mount higher on the frame then the lower front mount. When the lower rear mount is higher on the frame then the lower front mout when you adjust your lean out to fix a pull you end up changing the tow setting in the wrong dirrection making it very hard to find the sweet spot on the alignment.
xs1100sgman
Posted 8/28/2012 8:49 PM (#66589 - in reply to #66526)
25
jaydmc - 8/27/2012 1:09 PM We have every thing you will need for this. The bike side mounts run $675 Unlike most other mounts for your bike on the market, Our mounts do not place the lower rear mount higher on the frame then the lower front mount. When the lower rear mount is higher on the frame then the lower front mout when you adjust your lean out to fix a pull you end up changing the tow setting in the wrong dirrection making it very hard to find the sweet spot on the alignment. Jay G DMC sidecars www.dmcsidecars.com 866-638-1793
 Thanks for the response Jay, unfortunately that price is out of my grasp. I now realize that I only need the bottom rear mount so that is what I am putting the focus on at this point. I will also be looking to buy a seat cover so that would be another thing I need a price on. It is a Champion Escort, the same as my avatar.
 Regards,
Les
