Using turn signals ALSo as rnning lights on older BMW
Dr. Raoul Duke
Posted 8/1/2004 9:09 PM (#4275)
Subject: Using turn signals ALSo as rnning lights on older BMW
I have a 1974 R90/6 and I want to be able to use the front and rear turn signals also as running lights. Is there a replacement bulb out there that can handle both these function? If not, I am, open to alternative suggestions.
TIA,
Dr. Raoul Duke
Posted 8/2/2004 4:30 PM (#4298 - in reply to #4275)
Subject: RE: Using turn signals ALSo as rnning lights on older BMW
2000200050010010010025
Mr. Dr.,
In order to use your turn signal lights as running lights you will have to replace the wiring to use a double contact socket in the lamp fixture. If the turn signals are just single function lamps they only use a single contact lamp and socket. This would be replaced with a dual contact lamp (Stop/taillight lamp).
Wire the lower candlepower side to the taillight circuit and the high candlepower filament to your turn signals. You might want to toss in a heavy duty turn signal relay at the same time.
Loo4two
Posted 8/3/2004 11:49 PM (#4321 - in reply to #4275)
I have a 1976 Gold Wing and the front turn signal lights are dual filiment and use 1157 bulbs. The rear are single filiment but the dual pig tail can be made to fit.
David
