Wanted Subframe for BMW airhead or Guzzi Tonti Frame
flying_finn
Posted 9/10/2013 2:37 PM (#73901)
Subject: Wanted Subframe for BMW airhead or Guzzi Tonti Frame
Looking for a subframe for a BMW r100/7 or a tonti framed moto Guzzi V1000 G5
flying_finn
Posted 9/10/2013 3:14 PM (#73903 - in reply to #73901)
Subject: RE: Wanted Subframe for BMW airhead or Guzzi Tonti Frame
here is a photo of the Sidecar that will be mounted http://motomessiah.blogspot.com/2013/09/ural-sidecar.html
jaydmc
Posted 9/11/2013 3:45 PM (#73935 - in reply to #73903)
Subject: Re: Wanted Subframe for BMW airhead or Guzzi Tonti Frame
100050025
Of course we make both and are local to you.
We do not have an air head in the shop right now for you to see however we do have a Convert which as you know is almost the same as a G-5. We also often open the shop up after Moto Guzzi club breakfasts as the breakfast is only about 10 minutes from us.
Pfestus1
Posted 9/12/2013 8:11 PM (#73977 - in reply to #73901)
Have you found your subframe? I have a sidecar rig based on a R100RS. I am thinking about taking the bike back to solo, and removing the subframe and leading link. The sidecar I have on the R100 is a larger Motorvation Formula 11 that is a bit big and heavy for the Airhead. I have another rig, a Dnepr on a R75/5. With a lower final drive this is a good handling and fun rig.
The sub frame on the R100 is a custom made frame by a guy in West Virginia that used to be a sidecar rigger, Sidecar Magic Shoppe. The leading link is a EML set up with mounts for Brembo brakes.
Let me know if this is something of interest to you.
flying_finn
Posted 9/12/2013 9:43 PM (#73979 - in reply to #73901)
Howdy Hank,
Yes I have a interest. I already have a 31/9 rear end set aside for the BMW. I will send you a PM.
