Car wheels on URAL
Posted 11/14/2004 1:37 PM (#5336)
Subject: Car wheels on URAL
I would like to mount carwheels on my URAL now the rear wheel is in the center when i will mount a carwheel from 6" or 7" the wheel is out off the center does that mather.
I think when the rear wheel is out off center to the left side (from behind view) it wil ride better.
Thanks in front.
Posted 11/14/2004 1:52 PM (#5337 - in reply to #5336)
Subject: RE: Car wheels on URAL
2000200050010010010025
If you have a right side mounted car, having the wheel rim and tire set more to the left would cause less strain on the axle. Since you have a cantilevered axle (unless it has been modified), having the weight and load concentrated closer to the swing-arm will reduce the shear forces and torsional forces on the axle and swing-arm. This will reduce the tendency to bend the axle or twist the swing-arm even though the wheel/tire assembly may be heavier than the original one.
Posted 11/14/2004 2:00 PM (#5338 - in reply to #5336)
So if i understand it good it's better out off center when the sidecar is on the right the wheel mounted to the left.
