Harley Mounts Question
Korny
Posted 9/22/2015 3:25 PM (#86284)
Subject: Harley Mounts Question
Help!
Does anyone know if the mounts would be the same for a 1999 FLHTCUI (Ultra Classic) and a 2002 FLHR (Road King)?
Got a chance to add a car to the Ultra and if mounts would be compatible, will probably do it.
Thanks for your help.
Edited by Korny 9/22/2015 4:38 PM
davet
Posted 9/22/2015 5:24 PM (#86285 - in reply to #86284)
Subject: Re: Harley Mounts Question
Veteran
100100
What year is the sidecar? There are a few differences in the lower mounts depending on how old the sidecar is but if it is currently attached to the 2002, it should fit the 1999. Attached is a set of installation instructions and a picture of my lower mounts from a 1996 TLE. The newer rear mount has two bolts instead of three, and the newer front lower mount only attaches to the right front down tube, but the older mounts will work on your 1999. If your frame has the hex fitting shown in the second picture, you can use the older rear mount. It is just rearward of the right passenger footboard.
Edited by davet 9/22/2015 5:36 PM
(IMG_20150728_094903538.jpg)
(IMG_20141113_122902560.jpg)
Attachments IMG_20150728_094903538.jpg (2441KB - 0 downloads)
Attachments -J03263.pdf (1315KB - 3 downloads)
Attachments IMG_20141113_122902560.jpg (2210KB - 0 downloads)
davet
Posted 9/22/2015 5:41 PM (#86286 - in reply to #86284)
Veteran
100100
Here is another set of installation instructions, this one or the one from my previous reply should be what you need.
Attachments -J00803.pdf (2851KB - 14 downloads)
Korny
Posted 9/22/2015 6:39 PM (#86288 - in reply to #86286)
Thanks for the information!
