wiring tail lights
itshimself
Posted 8/8/2016 7:46 PM (#90261)
Subject: wiring tail lights
New User
i have a burgman 650 with a sidecar.the car came with russian ural front and rear lights mounted on the fender.the car is a texas ranger.it came wired to the car with an extension and plug to mount to the burgman.so far I'm at a loss to connect the wires and get everything working.any ideas will be great.
OldSchool_IsCool
Posted 8/8/2016 8:32 PM (#90262 - in reply to #90261)
Subject: Re: wiring tail lights
Extreme Veteran
100100100100252525
Are you wanting just a tail light on the car's fender or do you want it to also be your right turn signal? How about the front of the fender? Need it to be a marker light only or a combo with right turn as well?
Oh, and welcome to the forum!!@
Edited by OldSchool_IsCool 8/8/2016 8:33 PM
Al Olme
Posted 8/8/2016 9:12 PM (#90263 - in reply to #90262)
1000500100100252525
If they haven't changed since I had one, the rear light assembly has a separate turn signal and a combination [1157] brake and tail light. The font is a running light and a turn sognal.
What are you asking? Wire color codes? How do you connect to your Bergman? ???
jaydmc
Posted 8/9/2016 10:27 AM (#90269 - in reply to #90261)
100050010025
I am attaching our full mounting instructions for the Burgman, You will see that our mounts do not interfere with the use of the front of the floor board like some others but more important at the bottom of the instructions are the wiring instructions.
(Cut Out, upper rear panel (with instructions).bmp)
(Cut Out,upper front panel (with instructions).jpg)
Attachments Burgman 650 Instr 1-4-07.docx (1411KB - 3 downloads)
Attachments Cut Out, upper rear panel (with instructions).bmp (1612KB - 11 downloads)
Attachments Cut Out,upper front panel (with instructions).jpg (113KB - 2 downloads)
