Shaft or Belt
"RT"
Posted 10/3/2016 7:02 PM (#90928)
Subject: Shaft or Belt
I am looking at a M72B sidecar. I have 2 Yamaha's, a Vstar 1100 and a Roadstar 1600. I don't plan on a lot of long trips. Mostly around are little town trips. I am looking for input as to weather to use the VStar 1100 Shaft drive or the Roadstar 1600 belt drive. Any info would be a help.
VLAD
Posted 10/4/2016 9:32 AM (#90933 - in reply to #90928)
Subject: RE: Shaft or Belt
Extreme Veteran
10010010010025
Shaft will be no problem at all. Just replace gear oil in final drive sometimes. Belt will need more attention.
I like shaft.
jaydmc
Posted 10/4/2016 10:40 AM (#90934 - in reply to #90928)
Subject: Re: Shaft or Belt
100050010025
It does not make that much of a difference and should not be why you chose which bike. You need to decide which bike you want to ride with the sidecar.
Posted 10/4/2016 12:01 PM (#90936 - in reply to #90928)
2000200050010010010025
Either drive should last 50K miles or more. Negligible power loss from friction with shaft drive.
NWSC
"RT"
Posted 10/5/2016 4:24 PM (#90948 - in reply to #90928)
Thank you for your info. Decided to put one on both. One for my wife and one for me. Thank you again "RT"
VLAD
Posted 10/5/2016 4:56 PM (#90949 - in reply to #90948)
Extreme Veteran
10010010010025
Way to go.
Peter Pan
Posted 10/6/2016 12:26 PM (#90957 - in reply to #90928)
10005001001001001002525
Location: Now D-Bäk else San Isidro de Heredia, Costa Rica
Argh.
RT-Hanson.
I am jealous, such an answer from my wife would be a gift from heaven.
sparechangeter
Posted 1/24/2017 2:10 PM (#92095 - in reply to #90928)
NO difference. I have a California I on my 2007 Yamaha Roadstar XVZ-1700.
The more power/torque the better.
sparechangeter
Posted 1/24/2017 2:17 PM (#92096 - in reply to #90934)
No difference but size of bike does matter. I have a 2007 Yamaha Roadstar XVZ-1700 w/ a California I sidecar w/ electric trim. WORKS GREAT! My small dog loves it, my granddaughter loves it and my wife loves it. All different weights but the bike handles all well.
My prior ride was a 1984 Yamaha XVZ-1200 (running great and shaft drive!) w/ same sidecar and prior to that was my Hondasaki 750cc. (also running great w/ chain drive.) So? The chain drive was the most challenging. (sprocket and chain changes).
Hope this helps
