Triumph T-100 tree's
jaydmc
Posted 10/27/2016 2:45 PM (#91241)
Subject: Triumph T-100 tree's
1000500100
We just put the triple tree's for the T-100 back into production and got the first batch back from being anodized black today. All but two are pre sold $1000
stancotreau
Posted 10/28/2016 7:47 AM (#91249 - in reply to #91241)
Subject: Re: Triumph T-100 tree's
Regular
2525
Jay, I have a T100 / Velorex rig. What is the advantage of your triple trees? Is it just easier steering? or is there another benefit to them?
just trying to understand.... Stan
jaydmc
Posted 10/28/2016 10:39 AM (#91253 - in reply to #91241)
1000500100
Much easier steering. Also makes any front end shake you may have easier to control.
Al Olme
Posted 10/28/2016 11:19 AM (#91254 - in reply to #91253)
10005001001002525
Jay's right, as usual but there's another important point. Solo bikes that run conventional front forks are designed to accomodate stress in just one direction. Think about it, even when you are leaned way over the stress is applied to the sliders in a straight line. They never see and side stress. In a sidecar application, your front end has to deal with side loading every time you turn. Leading link suspension is designed to accept those loads. Sliders will work but not as well and occassionally they suffere from "stiction" when stressed and will fail to compress properly. Leading links are an overall better suspension for sidecars.
jaydmc
Posted 10/28/2016 11:25 AM (#91255 - in reply to #91241)
1000500100
Yes, a leading link is a better set up however with stock sized tires on the front even if you go with a flat profile sidecar tire for more traction on the ground the larger diameter fork tubes that have been the trend for about the last 20 years seem to work just fine with just changing out the triple trees. Triple tree's keep a more or less stock look to the bike and are significantly less money. The also do not require a different front fender so you need not worry about painting a front fender as you would with a leading link.
jkmolt
Posted 10/30/2016 6:39 PM (#91280 - in reply to #91241)
Veteran
100100
What is the installation cost, and how long do you need the rig. I have an 09 T100 w/Velorex, too.
jaydmc
Posted 10/31/2016 11:27 AM (#91295 - in reply to #91241)
1000500100
$400 and 1/2 a day.
