Harley 16" rear tire replacement?
Tex
Posted 5/18/2010 7:01 PM (#51350)
Subject: Harley 16" rear tire replacement?
I have a Ural mounted to my 2003 Road King. The rear tire (stock HD Dunlop) gies away every 4,000 miles. Can anyone recommend a flat tread car tire or hard compound motorcycle tire in 16"?
Thanks! TEX
DocWobblin
Posted 5/20/2010 3:51 PM (#51386 - in reply to #51350)
Subject: Re: Harley 16" rear tire replacement?
You might try a metzler 880 marathon in a bias ply...still a mc tire but I got outstanding mileage (15000/18000) on them on BMW K1200ltc. You might look through sears or another tire shop and look for a car tire that is maybe 5 to 10 mm wider than your current HD tire. I've got a Dunlop sp7000 car tire in a 185/55/16 on my 09 Ultra Classic, however the 09's and up have a wider rear tire stock(180/60/16) than the earlier model bikes. FWIW..
Tex
Posted 5/20/2010 5:08 PM (#51387 - in reply to #51386)
Doc, fantastic recommendations and I thank you! I have access to a contractor who supplies many cities in the Phoenix area with standard and specialty tires.
I sure appreciate your advice. I've been searching for a while and yours is the first cogent advice I've received.
Thanks! Tex
46u
Posted 5/20/2010 7:09 PM (#51390 - in reply to #51350)
Dunlop E 3 last longer and is what they put on all the new Harley s. Are you sure you have every thing set up properly as I know others running sidecars on Harley s with D 402 and last a good bit longer then what you are getting.
46u
Posted 5/20/2010 7:40 PM (#51392 - in reply to #51350)
I just asked a friend of mine that has a 1988 FLHS that has a BIG Watsonian Cambridge on it and he runs D402 and gets 6 to 7 K out of his rear tires. Then my friends running Harley sidecars are getting 8K or better out of theirs. I would think with a E3 set up properly you should get 11 to 12K or better.
mwnelson
Posted 6/1/2010 6:51 PM (#51617 - in reply to #51350)
Subject: RE: Harley 16" rear tire replacement?
What front/rear tire pressures are being run? I have an '01 RK with TLE and got 6500 out of my first dunlop.
46u
Posted 6/1/2010 7:04 PM (#51619 - in reply to #51617)
mwnelson - 6/1/2010 7:51 PM
6500 out of the rear or the front? According to my two TLE manuals they recommend the same in the front as for a solo 36 PSI.
Posted 6/2/2010 1:19 PM (#51644 - in reply to #51617)
6500 miles is about average for the OEM Dunlop rear skin.
46u
Posted 6/2/2010 1:24 PM (#51645 - in reply to #51644)
Hack'n - 6/2/2010 2:19 PM
Is this true for the latest tire HD is running the E3 Dunlop for the last couple of years on them? I know in solo form they are getting around 4 to 6k more out of them then the D402 they use to run on the touring models. With the E3 many are getting over 16K in solo form on the rear. When I wear out the set I have now I will be trying a set of the E3.
