Random quote: Riding a motorcycle is the 2nd Best feeling on the planet, and I get it way more often than the best feeling....................("Eating", Man get your mind out of the gutter....HA HA)
- (Added by: Tikiman100)
Camber? Toe-in?
DianneB
Posted 12/6/2014 11:20 AM (#81520)
Subject: Camber? Toe-in?
Is there a generally-accepted target figure for camber in sidecar design? Zero? Positive? Negative?
I assume caster is zero?
How about the range of toe-in adjustment?
jaydmc
Posted 12/8/2014 10:39 AM (#81557 - in reply to #81520)
Subject: Re: Camber? Toe-in?
1000500100
See attachment.
Toe in also depends on factors such as wheel base of the bike as the longer the wheel base the larger the measurement you will have as you are reading over a longer length. Type of tire also makes a difference. Automotive tires take a bit more toe then motorcycle tires.
jay@dmcsidecars.com
Edited by jaydmc 12/8/2014 10:41 AM
Attachments BASIC SIDECAR INSTRUCTIONS.doc (388KB - 37 downloads)
