Random quote: Once you establish yourself as eccentric, you rarely have to explain your actions.
- (Added by: Boltsrightup)
Rear Top Mount Location ?
Sal
Posted 12/7/2014 2:32 AM (#81533)
Subject: Rear Top Mount Location ?
Regular
252525
Hi folks, I'm needing advise on where to mount this top rear mount. The bike is a Kawasaki Vulcan 800
In order to keep the attachment high I'm thinking that the fender strut bolt (arrow pointing) will be a good place .
The fender strut is pretty stout. Do you guys think it's a good location?
 This is the same bike model with an "iffy" mount...
DianneB
Posted 12/7/2014 7:29 AM (#81534 - in reply to #81533)
Subject: Re: Rear Top Mount Location ?
I have seen that location used by some sidecar makers so I presume it has been successful.
Sal
Posted 12/7/2014 7:29 PM (#81546 - in reply to #81533)
Subject: RE: Rear Top Mount Location ?
Regular
252525
Thanks, top mount attached to fender strut...
Sal
Posted 12/7/2014 7:34 PM (#81547 - in reply to #81533)
Regular
252525
Another question...
Can the rear top arm be straight (vertical) or is it better to be set at an angle (top further away than at bottom)?
jaydmc
Posted 12/8/2014 10:36 AM (#81555 - in reply to #81533)
1000500100
Make a plate that picks up both of the bolts at the front of this chrome plate near the seat base. They single eye bolt you show may also work very well depending on what it is going into and the diameter of the shank. You do not want your strut straight up and down.
While it has been so long since we have done an 800 I forgot we even had the mounts for it. I looked it up and we do make mounts. I have attached the full instructions which show all of the hardware.
jay@dmcsidecars.com
Attachments Kawasaki Vulcan 800 Mounting Instructions.doc (2876KB - 33 downloads)
