Random quote: No problem is so big or so complicated that it can't be run away from
- (Added by: dave)
dyna III ignition/Reverse
op200
Posted 12/1/2004 7:23 AM (#5490)
Subject: dyna III ignition/Reverse
Remember me? I'm the ass**** that stuck a starter on the sidecar wheel and blew up his Dyna II ignition controller. well I finaly figered out what happened. To back up I pulsed the starter, each on time draged the battery down to almost o volts then I released it, allowing the battery to recover. When it was on a tremous mag. feild built up, then when I released it, the colapsing feild on the starter winding made a huge reverse voltage spike. Evan though the solenoid contact were open, there must have been a spike big enough to jump them and blow up the controller.
Posted 12/1/2004 6:39 PM (#5495 - in reply to #5490)
Subject: RE: dyna III ignition/Reverse
Ben -
I'm impressed you traced the problem to something as obscure as a collapsing magnetic field. Nice job and thanks for sharing the solution to the riddle.
Jim
