Sidecar.com Forum ->  Classified Ads -> 3. Miscellaneous Sidecar Related for Sale -> View Thread
Random quote: Good judgment comes from experience, and a lot of that comes from bad judgment.
Bolt on Suspension upgrade for Velorex sidecars Plus.
Moderators: dave
   Classified Ads -> 3. Miscellaneous Sidecar Related for SaleMessage format
Posted 1/18/2015 1:47 PM (#82255)
Subject: Bolt on Suspension upgrade for Velorex sidecars Plus.
2000200050010010010025
This Bolt on conversion kit allows pre 2005 Velorex sidecars to support larger bikes with 1,100cc's or more, also for heavy loading and dual sport work.
Fits all 15mm axle Velorex's 562, 562E and 700 models. No more bottoming out or wallowing in the turns, great for dual sport work.
Swingarms with the 15mm axles were designed to support a 350# JAWA or MZ. My swingarm will support a bike almost twice that weight.
Uses modular wheel with 4.80x12" or 5.35x12" flat tread tire. Includes Heavy Duty swingarm with 1" axle, standard 4"on 4" hub with Timken bearings.
Straight bolt on modification. No welding or other mods needed. $300. with US shipping.
Lonnie Cook, Ret'd.
Boise, Idaho
Ph. 208-629-8409
nwsidecar@aol.com
Edited by Hack'n 12/7/2016 5:36 PM
(Velorex HD Option 562 & 700S (Medium).jpg)
(Velorex H-D Suspension option 2 (Medium).JPG)
Attachments Velorex HD Option 562 & 700S (Medium).jpg (97KB - 12 downloads)
Attachments Velorex H-D Suspension option 2 (Medium).JPG (82KB - 15 downloads)
cycleboy
Posted 2/28/2015 2:41 PM (#83134 - in reply to #82255)
Subject: RE: Bolt on Suspension upgrade for Velorex sidecars.
How can I tell if my (new to me) 562 standard has this mod already installed. I've been told it is a pre 2000 model. The suspension seems a bit soft. It is on a large bike (Yamaha VSTAR 1100). It was installed by Sidestrider (Doug B.), so I'm assuming the necessary mods were performed for this bike. The only obvious mod I can see is a large steel ballast plate below the car. There is also a steering dampener. Thanks in advance for your help!
Posted 2/28/2015 3:07 PM (#83135 - in reply to #82255)
Subject: Re: Bolt on Suspension upgrade for Velorex sidecars.
Cycleboy,
If you have the stock spoked wheel and your swingarm looks like #23 on the attached illustration you have the original swingarm with a 15mm axle.
(Image (3).jpg)
Attachments Image (3).jpg (341KB - 8 downloads)
cycleboy
Posted 2/28/2015 3:40 PM (#83136 - in reply to #82255)
Lonnie, thank you for the quick reply! So, the original lower shock attachment is in front of the axle and the HD conversion it is behind? What other parts are necessary for the conversion? Will the original fender still work? Does the new hub have a 5 bolt pattern? Where are those wheels available?
Posted 3/1/2015 12:19 PM (#83145 - in reply to #82255)
Our bolt on suspension upgrade uses a heavy duty swingarm with 1" axle. The hub is now 4 lug.
It uses a 12" modular wheel with a 4.80 series flat tread tire.
Chrome, galvanized or powder coated wheels are widely available from trailer supply stores, Lowe's, home Depot, Harbor Freight and others.
Nothing else is needed. The kit is priced at $300.00 including US shipping.
cycleboy
Posted 3/1/2015 1:38 PM (#83147 - in reply to #82255)
Great, PM sent.
Sal
Posted 3/1/2015 3:12 PM (#83150 - in reply to #82255)
Regular
252525
Pm sent
cycleboy
Posted 3/3/2015 8:29 PM (#83195 - in reply to #82255)
Did this sell?
Posted 3/3/2015 9:18 PM (#83196 - in reply to #83195)
The "in stock" Suspension kit was sold, but I can fabricate one on a special order. $300.00 with US shipping.
cycleboy
Posted 3/4/2015 9:41 PM (#83217 - in reply to #82255)
Interested, PM me off line or check your PM's
Jon
Posted 3/7/2015 11:15 PM (#83257 - in reply to #82255)
Regular
252525
How about the /2 collet mount kit? Got any?
Jon , ALABAMA
Posted 3/8/2015 1:22 PM (#83261 - in reply to #83257)
Collet kit?
I have collets and the URAL weld on ball mounts as shown in the pix. I have a couple of balls with threaded stub that I use for subframe fabrication.
High Octane
Posted 7/21/2015 1:52 PM (#85501 - in reply to #82255)
Subject: Re: Bolt on Suspension upgrade for Velorex sidecars Plus.
25
Would this suspension kit be adaptable to using a different wheel, like a v storm 19" front? Or maybe a 17 motorcycle wheel?
Posted 7/21/2015 2:42 PM (#85502 - in reply to #82255)
No, just 4 lug bolt auto type wheels.
High Octane
Posted 7/21/2015 11:52 PM (#85508 - in reply to #82255)
25
I was afraid of that. I'm researching whether I want to fit a velorex up to a dual sport bike I have or if I should find a heavier duty sidecar. The axel upgrade is a must but I'd like to use the same mc tire that I have on the bike if possible. I have a 19" front wheel and a 17" rear.
