Random quote: If the facts are against you, argue the law. If the law is against you, argue the facts. If the law AND the facts are against you, pound the table and yell like hell! - Carl Sandburg
Velorex 560.question
Snakeoil
Posted 3/16/2015 11:33 PM (#83433)
Subject: Velorex 560.question
Regular
2525
I did a search, but did not find an answer. What is the axle size on a Velo 560? Would it be suitable for use with a 400 lb bike? I know that they have been used on all types and sizes of bike, but that does not mean it is a good idea.
Thanks,
Rob
jaydmc
Posted 3/16/2015 11:54 PM (#83435 - in reply to #83433)
Subject: Re: Velorex 560.question
100050025
15mm, 400 lbs is only part of the equation, how wide it is, what it is going to be carrying and how heavy is the rider, how top heavy is the bike? In general, if mounted properly it should be fine however ballast may be needed.
Snakeoil
Posted 3/17/2015 9:28 PM (#83461 - in reply to #83435)
Regular
2525
Thanks. I had gotten the impression that a 15mm axle was small for a mid weight bike. I appreciate the input on the other variables. I realize it's a lot more than axle size.
I might put a car on my R100/7. Just noodlin' at this point.
Thanks,
Rob
jaydmc
Posted 3/18/2015 12:13 AM (#83465 - in reply to #83433)
100050025
With ballast and proper mounts it will work fine on a /7
The /7 does require sub frames as the frame tubing is quite thin.
We of course make sub frames.
