Random quote: If motorcyclists claim to be individuals, why then, do so many of them ride in packs?
- (Added by: DAVE)
Harley Upper Mount Clunk
kmev
Posted 4/14/2015 8:33 PM (#83909)
Subject: Harley Upper Mount Clunk
I'm getting clunking from the front, upper mount on my '72 Harley - mostly when turning in a tight radius and sometimes on large bumps. Is that normal, and how much should that spring be compressed? I greased the mount and tightened the nut so the spring was half compressed. Maybe I need to tighten it more?
I'm having fun with the rig and the ability to haul stuff around. The bike was little used in the last 5 years, so this is a welcome change.
46u
Posted 4/19/2015 11:43 AM (#83979 - in reply to #83909)
Subject: RE: Harley Upper Mount Clunk
Elite Veteran
500100100100
I would like to know this too. Mine has been making noise similar to what you are saying mine is more like a squeak for over 20,000 miles so far not a problem. I do recommend checking the torque on all fasteners. I have checked mine many times but yet found any loose.
Looking forward to what other have to say!
davet
Posted 4/19/2015 7:42 PM (#83995 - in reply to #83909)
Subject: Re: Harley Upper Mount Clunk
Veteran
100100
Can you post a picture of the mount? Not sure I know what the spring is you are talking about. Thanks
Posted 4/20/2015 11:39 AM (#84008 - in reply to #83909)
2000200050010010010025
Could it be just the clearance between the mounting bolt and the hole in the mount? Tightening the spring won't change this gap.
(DSCF2972.JPG)
Attachments DSCF2972.JPG (109KB - 0 downloads)
kmev
Posted 4/23/2015 10:54 PM (#84062 - in reply to #83909)
I am trying to post a pic of my mount, but I haven't been able to get it to work for the last few days.
davet
Posted 4/24/2015 6:52 AM (#84065 - in reply to #83909)
Veteran
100100
I have the newer TLE mounts so I don't have a spring on that mount. Maybe you can see if the mount is moving by using a zip tie or something.
timo482
Posted 4/24/2015 10:49 PM (#84085 - in reply to #84065)
Elite Veteran
50010025
mine is newer and has a cone and a spring... with the cone it stays tight
