Random quote: Dim-witted drivers don't do well with surprises.
- (Added by: SidecarMike)
Front tyre
Sidcar
Posted 4/27/2015 3:09 AM (#84107)
Subject: Front tyre
Regular
252525
Hi folks
I'm running an Austone taxi tyre on the rear of my GL1500/Oxford outfit so now that the front tyre is nearly worn out what do I replace it with?
Sid
VLAD
Posted 4/27/2015 9:02 AM (#84110 - in reply to #84107)
Subject: RE: Front tyre
Extreme Veteran
10010010010025
I use pilot active rear tire 130/70-18.
AJ1200
Posted 4/27/2015 9:52 AM (#84112 - in reply to #84107)
Subject: Re: Front tyre
Extreme Veteran
100100100
Same here and I'm very happy with the performance
SidehackRalf
Posted 4/27/2015 10:50 AM (#84121 - in reply to #84107)
Veteran
10025
That's what I use, good tyre.
Sidcar
Posted 8/13/2015 3:54 AM (#85802 - in reply to #84107)
Regular
252525
Hi, I'm just about to part with some of my hard earned cash for Pilot Active tyre when I'm told that Avon make a Cobra Trike tyre. Has anyone used one if so are they any good. The tyre needs to be VERY good as it's twice the price!
Sid
fastjoe
Posted 8/13/2015 6:23 AM (#85803 - in reply to #84107)
Veteran
1002525
When you run a rear on the front which way to you have the rotation arrow? Same as it would be if it was on the rear? or backwards?
Posted 8/13/2015 1:17 PM (#85817 - in reply to #84107)
2000200050010010010025
Reverse the directional arrow. A front tire uses the tread design for braking. A rear use it for traction. Reversing the arrow allows more braking traction on the front wheel.
fastjoe
Posted 8/13/2015 3:17 PM (#85820 - in reply to #85817)
Veteran
1002525
Thank you.
Does it still work well in the rain? Have you noticed any issues?
My apologies for the hijack.
Edited by fastjoe 8/13/2015 3:18 PM
Posted 8/13/2015 6:25 PM (#85823 - in reply to #84107)
Might be a bit better in the rain since the front tire does the brunt of the braking.
