Random quote: The farther back you can look, the farther forward you are likely to see. - W. Churchill
- (Added by: Wiskers)
How I mounted my TLE to my Softail
Fuzzybeard
Posted 5/9/2015 2:49 PM (#84293)
Subject: How I mounted my TLE to my Softail
This has come up more than once. So, since I don't get on very often, I thought I'd make a post to show how I accomplished my connection. That way it can be properly shared, discussed, ripped apart, condemned, etc.
To begin, this is a 99 FLSTC and a 93 TLE. I have no idea what process would be involved with any other setup. Honestly, I made all this up anyway! Let's dig in.....
 The hardest part was coming up with a rear mounting point. What I came up with was a 3/8" steel plate that mounts to the passenger footpeg mounting point on top and the two exhaust hanger bolts on the bottom. To this I had a piece welded on to create a mount with a 2" stand-off.
For the front I found this bar at the local farm store
 http://www.farmandfleet.com/products/694902-double-hh-category-1-stabilizer-arm.html
 I cut it into two lengths, did a thousand more measurements and came up with an upper and lower mount that I u-bolted to the frame. Since I don't trust anything I do, I got crazy and doubled up on the U-bolts on each bar. I then got to wondering about the u-bolts shifting up and down the frame during a high stress event and decided to tie them together with a couple of pieces of flat stock.
dawg gone
Posted 5/11/2015 10:10 AM (#84322 - in reply to #84293)
Subject: RE: How I mounted my TLE to my Softail
Regular
252525
nice looks stout enough, upper mount to lower mount subframe great stability.
How do the rear shocks hold up to the extra weight? I have a Spyder on my '07 and it is a bit softer than I would like,
prmurat1
Posted 5/12/2015 4:04 PM (#84342 - in reply to #84293)
Regular
252525
Nice mounts!! I installed a Companion GT on my -89 Softail but I went the easy way with a DMC mounting kit... Changed the front wheel for a 16" (had a 21"), longer tubes and raked triple trees...
Edited by prmurat1 5/12/2015 4:10 PM
Fuzzybeard
Posted 5/12/2015 5:47 PM (#84351 - in reply to #84293)
Subject: Re: How I mounted my TLE to my Softail
Thanks guys! I went this route for a few reasons. Number one, I'm cheap. Because I had the rear mount made up at work (free) I only have like $40 into the mounts. Number two, I had a lot of people tell me I couldn't or shouldn't do it and I'm stubborn that way. Number three, I'm cheap.
I haven't actually noticed a difference in the rear suspension with this rig, maybe since the car doesn't have a suspension it is less noticeable.
I also added raked trees to my bike, but I'm thinking of taking them back off. They did make it slightly easier to steer but I also got more bump steer now than I like, again lack of suspension on car.
