Random quote: You can hit small with a big hammer ...But you cant hit big with a small hammer..
Linear actuator - rebuild info needed
1bmwmc
Posted 7/9/2015 10:03 PM (#85303)
Subject: Linear actuator - rebuild info needed
25
I have a 1993 BMW K1100LT with a Hannigian Sport. The E.C.C. (linear actuator) does not work. Wiring ok. An online search finds similar actuators but without the welded on mounts. Which tells me getting mine repaired/rebuilt/overhauled would be the best route to take.
Can any one point me towards a person/shop/business that does that sort of work?
Or should I replace it with a solid strut.
Thanks in advance for any and all comments.
(DSC04299.JPG)
Attachments DSC04299.JPG (1429KB - 0 downloads)
Al Olme
Posted 7/9/2015 10:54 PM (#85304 - in reply to #85303)
Subject: RE: Linear actuator - rebuild info needed
1000500100100252525
Have you called Hannigan about a replacement? Their prices aren't unrealistic on most of their parts. A rebuild [if possible] might not be less expensive than a replacement.
1bmwmc
Posted 7/10/2015 7:23 AM (#85309 - in reply to #85304)
25
Yes I plan on contacting them - gathering up as much info as possible before proceeding.
OldSchool_IsCool
Posted 7/10/2015 11:17 AM (#85310 - in reply to #85309)
Subject: Re: Linear actuator - rebuild info needed
Extreme Veteran
100100100100252525
Often the actuator will have a specification plate/tag on it specifying the stroke length, strength (dynamic and static) and speed. With those specs, you may be able to source an actuator on the open market.
draperg1
Posted 7/15/2015 8:51 PM (#85403 - in reply to #85303)
Veteran
1002525
when mine gave out I found Hannigan's price was cheaper than a new one that needed modifing
1bmwmc
Posted 7/18/2015 5:37 PM (#85448 - in reply to #85303)
25
New Hannigan piece arrived today - thanks to all for the input.
1bmwmc
Posted 8/6/2015 2:50 PM (#85690 - in reply to #85303)
25
Does anyone have a picture of their swing arm with shock & actuator installed with the wheel off? Having a bit of a struggle getting things to line up.
As allways thanks in advance.
