Random quote: Lessons learned are for sissys.
Air vents for side car?
Mike o
Posted 6/1/2016 10:57 PM (#89333)
Subject: Air vents for side car?
Hello,
Sorry if this was covered before. I'm looking to add an adjustable fresh air vents on a Motorvation Roadster sidecar. Any ideas to keep my posse happy! In floor, hood scoop or in windshield. Ideally it would be easy to install without looking jerry rigged. Any thoughts?
Edited by Mike o 6/1/2016 11:13 PM
Attachments image.jpeg (384KB - 35 downloads)
Attachments image.jpeg (769KB - 18 downloads)
Attachments image.jpeg (460KB - 15 downloads)
trikebldr
Posted 6/1/2016 11:36 PM (#89334 - in reply to #89333)
Subject: RE: Air vents for side car?
Veteran
100
Maybe down low on the side of the nose of the car between the car and bike. Be sure to provide some kind of water stop that will drain out under the car. NACA ducts do a fair job of not catching any water to begin with.
You could also add a high-volume fan to draw air through a duct that faces rearward.
What about colder weather? I made up my own heater with a fan for my Spyder hack. It tapped into the bike's water system. Just shut off the water valve to use for summer ventilation.
Al Olme
Posted 6/2/2016 12:18 AM (#89335 - in reply to #89333)
100050010010025
Many folks use circular aircraft vents from Aircraft Spruce http://www.aircraftspruce.com/menus/ap/vents_inlets.html in the windshield. Another common solution is a vent in the floor facing the rear. Place the vent so there's no chance of sucking in exhaust gasses. Make sure you provide a way to close the vent. For some reason lots of folks don't think about that.
AJ1200
Posted 6/2/2016 7:59 AM (#89337 - in reply to #89333)
Subject: Re: Air vents for side car?
Extreme Veteran
100100100
in my opinion that sidecar is ideal for a hood scoop as it has the design flow already. I would not cut into the windshield if it were mine.
I have a Motorvation FII and after seeing another one that someone here did I added a small hood scoop to mine, I used a RV grey tank valve as a water seal and flow control valve
My wife loves it as she can control the air flow at any given time. the scoop was for a small Honda car, not sure which one but there are tons of different styles out there
the other thing you have to decide is where you want to cut your hole for air flow. I don't think the bike side is a good idea as it could pull engine heat if it was not forward enough
the floor works good but in my opinion interferes with,,, well the floor,, and anything on the floor would restrict it's air flow
just my 2 cents worth, by the way nice posse
Edited by AJ1200 6/2/2016 8:03 AM
(vent 001.JPG)
(vent 002.JPG)
(vent 003.JPG)
Attachments vent 001.JPG (393KB - 1 downloads)
Attachments vent 002.JPG (744KB - 1 downloads)
Attachments vent 003.JPG (821KB - 2 downloads)
Al Olme
Posted 6/2/2016 11:45 AM (#89342 - in reply to #89337)
100050010010025
I like Ace's solution. Very clean and "factory looking". [Now if he could just get that alternator thing working... a VERY inside joke]
AJ1200
Posted 6/2/2016 12:08 PM (#89343 - in reply to #89342)
Extreme Veteran
100100100
Al Olme - 6/2/2016 11:45 AM
yes and much funnier now than it was then
thanks to all the great people involved it all ended well
Mike o
Posted 6/2/2016 12:33 PM (#89345 - in reply to #89333)
Thanks folks. I really like the scoop idea. Thanks for the pictures too!
VLAD
Posted 6/2/2016 12:42 PM (#89346 - in reply to #89345)
Extreme Veteran
100100100100
I bought sidecar with air scoop installed on front floor. Scoop made with abs plumbing pipes. Not fancy but works and you can't see it.
Edited by VLAD 6/2/2016 12:43 PM
Mike o
Posted 7/5/2016 8:41 PM (#89744 - in reply to #89333)
Update
After a bit of research, I decided to go with a vent from Florida sidecar products. It was a bit unnerving to cut a 4-1/2" hole in my sidecar.  One problem I ran into, the screws that come with the kit did not have a large enough head to hold vent ring in due to the sponginess (if that is a word) of the rug and curve of the body.  I picked this screw up at HD that did the trick.
 http://www.homedepot.com/p/Everbilt-3-16-in-x-1-4-in-Aluminum-Flat-Head-Slotted-Machine-Screw-with-Binding-Post-815581/204274860
 This vent works really well.  My doggies approve!  Here's a few pictures.  Sorry about the dog hair ??
Edited by Mike o 7/5/2016 11:44 PM
Attachments image.jpeg (33KB - 26 downloads)
Attachments image.jpeg (722KB - 17 downloads)
Attachments image.jpeg (581KB - 16 downloads)
Attachments image.jpeg (477KB - 20 downloads)
AJ1200
Posted 7/7/2016 11:38 AM (#89787 - in reply to #89333)
Extreme Veteran
100100100
Looks good Mike
