Random quote: "never approach a bull from the front, a horse from the rear, or a fool from any direction"
- (Added by: DAVE)
Hack tire...
Big Tom
Posted 7/3/2016 2:23 PM (#89696)
Subject: Hack tire...
Regular
252525
I just picked up my Rig and find I need a tire for the Sidecar. Currently has a Bridgestone Potenza on it in 165/65/R13. I did a search on here and found nothing about a Sidecar tire. Plenty of Darkside info though..
What's a good replacement for this tire since it has been discontinued? I need to get one soon as it's at the wear bars.. Here's a pic of my Sweety trying the rig on for size..
Sidewise
Posted 7/3/2016 5:13 PM (#89701 - in reply to #89696)
Subject: RE: Hack tire...
Regular
252525
http://www.carid.com/tires/165-65-r13/
jaydmc
Posted 7/4/2016 12:43 PM (#89711 - in reply to #89696)
Subject: Re: Hack tire...
100050010025
From the factory this sidecar more then likely had a 155 13 however a 165 will work. This is an automotive tire, any automotive tire store should have no problem helping you.
WinginCamera
Posted 7/4/2016 3:02 PM (#89716 - in reply to #89696)
Veteran
100100
Like Jay said, originally it was probably a 155/13 tire. I've never tried a 165.
I have used Firestone 745 F-560, size 145R13 24 psi and here is where I found them:
https://www.cokertire.com/145r13-firestone-f560.html $70.00
https://www.cokertire.com/145r13-vredestein-sprint.html $85.00
http://www.summitracing.com/search/part-type/tires/tire-size/145r13...
The sidecar tire I have on now is a Coker Verdestein Spint, 145R13, from Summit racing. $85.00 plus shipping, total $102.95 The Coker tire was a little more money but I wanted to see if it lasted a little longer. I average about 15,000 miles per tire. Since you indicate the Bridgestone Potenza 165/65/R13 will fit I might try the Bridgestone next time.
If your interested, on the rear of the bike I am running a 195/55R-16 Firestone Precision Touring at 28 psi
Big Tom
Posted 7/4/2016 3:20 PM (#89718 - in reply to #89696)
Regular
252525
OK new question... I was going to take the Wheel off to shop around local tire shops. I have nothing that will fit on the lugs to get them off. Where do I get the lug wrench for the job?
Posted 7/5/2016 1:58 PM (#89737 - in reply to #89696)
2000200050010010010025
Looks like you will need a thin walled socket for this one.
NWSC
Big Tom
Posted 7/6/2016 11:39 AM (#89763 - in reply to #89737)
Regular
252525
Hack'n - 7/5/2016 10:58 AM
NWSC
I will also now need 4 new Lug Nuts....
Here is what happened to the thinnest wall socket I had. 12 Point so it didn't treat the lug nuts well.. Chalk line is where it had to be tapped in with a BFH..
RoanokeRider
Posted 7/6/2016 11:43 AM (#89764 - in reply to #89696)
25
I have a similar wheel. No help getting the lug nuts now, but for future, mine came with much longer chrome lug nuts that stick out far enough to get a wrench on them. Likely can get them at any autoparts store.
Big Tom
Posted 7/6/2016 12:17 PM (#89765 - in reply to #89764)
Regular
252525
RoanokeRider - 7/6/2016 8:43 AM
Thanks for the tip.. I will look for them after I find a tire..
Big Tom
Posted 7/6/2016 4:51 PM (#89768 - in reply to #89696)
Regular
252525
Got those Chrome Lug Nuts today. Sure makes a difference..
jaydmc
Posted 7/6/2016 5:33 PM (#89769 - in reply to #89696)
100050010025
Get the chrome acorn type lug nuts, thread is 1/2 inch 20 tpi.
Any tire store should have them.
