Random quote: Ever notice that there are a lot more horses asses than there are horses?
- (Added by: Hack'n)
Steering Dampener Failed
Piper
Posted 7/21/2016 5:45 PM (#90015)
Subject: Steering Dampener Failed
New User
Hi,
In December I picked-up a Champion Vintage Sidecar. This has been a joy.
I was able to take a trip from Philadelphia to Iowa and back with no issues.
3 days after I returned, on the we to work, the bracket connecting the steering dampener to the front wheel broke.
I am very concerned as I only put about 3k miles on the rig.
Any ideas as to the cause and how it can be prevented.
(I am waiting for the dealer to pickup the rig as the nearest champion dealer is 1.5 hours away.)
(IMG_0464.JPG)
(IMG_0465.JPG)
(IMG_0467.JPG)
Attachments IMG_0464.JPG (3425KB - 0 downloads)
Attachments IMG_0465.JPG (3180KB - 0 downloads)
Attachments IMG_0467.JPG (3688KB - 0 downloads)
Al Olme
Posted 7/21/2016 6:36 PM (#90016 - in reply to #90015)
Subject: RE: Steering Dampener Failed
10005001001002525
Looks like the bracket was initially defective. I suspect that if you called Champion or maybe emailed them your pictures that they would send out another part so you could bolt it on yourself.
Posted 7/21/2016 9:31 PM (#90019 - in reply to #90015)
Subject: Re: Steering Dampener Failed
2000200050010010010025
They could stand to be beefier. Not much steel left after it's bored.
NWSC
jaydmc
Posted 7/22/2016 10:28 AM (#90025 - in reply to #90015)
1000500100
I have found that if you have your alignment correct and slightly over tighten the steering head bearings you do not need a damper. Dampers make your bike steer heavier which is the last thing you need. In general we do not use them and when we do have to use them we use a damper with much less dampening force then what Champion uses. I would see about running with out the damper.
