Random quote: its easier to stand at the bar drinking & sit down than it is to sit drinking & stand up. "my Dad"
GL1800 Wing rear suspension
foodog2
Posted 10/9/2016 6:43 PM (#91015)
Subject: GL1800 Wing rear suspension
252525
anyone have a problem with the rear shock/spring on a wing with a rig going bad?  I have a 13 wing with a Hannigan GTL I bought new and the bike bottoms out a lot now.  Seems to hit on the center stand and I never used to.
mulefour
Posted 10/10/2016 8:43 PM (#91027 - in reply to #91015)
Subject: Re: GL1800 Wing rear suspension
http://gl1800riders.com/forums/5-gl1800-tech-board/113709-preload-a...
This might help.
Bob
SideCar
Posted 10/15/2016 6:53 PM (#91111 - in reply to #91015)
Veteran
10025
Agree with the bleed, but depending on your situation, you may also want to install the Progressive spring, assuming your shock is still good. I have that spring on my 08 Wing (not hacked) and it is a good addition.
WinginCamera
Posted 11/13/2016 8:42 PM (#91421 - in reply to #91015)
Veteran
100100
I agree with the above about checking the bleeding & new spring. I put a Progressive spring on my 2003 and it made a big difference in ride. While you got it all apart check all those hose fittings. There is also a master ground wire to clean & check. I went and ran a second ground wire just for the fun of it.
