Random quote: A vote is like a rifle: its usefulness depends upon the character of the user. Theodore Roosevelt
Champion escort 10 pin connector
Valkrider
Posted 11/13/2016 1:19 PM (#91411)
Subject: Champion escort 10 pin connector
Veteran
100
Anyone have a number or manufacturer of the dual gender 10 pin wiring connector on the Champion Escort sidecar? also, what is the pictured black connector for?
Edited by Valkrider 11/13/2016 1:43 PM
Attachments image.jpeg (1393KB - 28 downloads)
Attachments image.jpeg (1279KB - 20 downloads)
CCjon
Posted 11/13/2016 3:14 PM (#91417 - in reply to #91411)
Subject: Re: Champion escort 10 pin connector
Extreme Veteran
1001001002525
Try calling here on Monday. Good luck.
EMAIL
BILLS@CHAMPIONSIDECARS.COM
OFFICE
11841 MONARCH ST
GARDEN GROVE, CA 92841
714-847-0949
800-875-0949
jaydmc
Posted 11/14/2016 10:39 AM (#91425 - in reply to #91411)
100050025
Two connectors in your photo. The metal one is for your brake quick disconnect. The other is for a radio antenna.
We normally cut the Champion plug off as their harness is far to long. This allows us to clean up the wiring.
You did not ask but I thought the pin out for the plug might be use full to you.
1 clock, green 22 gauge
2 accessory Red 18 gauge
3 Ground Black 18 gauge
4 Brake light Red 22 gauge
5 Running light White 22 gauge
6 Right Turn signal Yellow 22 gauge
7 back up Blue 22 gauge
8 Canopy switch on bike Orange 22 gauge
9 Tilt Yellow 14 gauge
10 Tilt Pink 14 gauge
Valkrider
Posted 11/14/2016 11:12 AM (#91427 - in reply to #91425)
Veteran
100
Thanks as always Jay. I had downloaded the Champion manual so had the pin out info, but that antenna connector was a mystery. I was looking for the plug model so could make my own harness to the bike.
Valkrider
Posted 11/21/2016 1:19 PM (#91479 - in reply to #91427)
Veteran
100
Champion only sells a harness and I really only need the connector. Anyone have info before I cut it off and replace with another type. Wire size up to 14 gauge if anyone recommends a particular replacement.
Valkrider
Posted 11/21/2016 8:50 PM (#91482 - in reply to #91479)
Veteran
100
Okay, in the unlikely event anyone else needs the info, the manufacturer is Sure Seal. Model pictured is their 120-1870-000. I ordered its matching part 120-1869-000
