Random quote: The trouble with retirement is you can't take a day off or even call in sick. And you have to live with the boss.
- (Added by: md835)
DMC on a 1998 Moto Guzzi V11
rtbain
Posted 2/16/2017 5:04 PM (#92391)
Subject: DMC on a 1998 Moto Guzzi V11
Installing a DMC sidecar on a 1998 Moto Guzzi V11 (California). Several items have been changed/upgrades prior to this post. I'm at the point where another pair of eyes is recommended.
Changes made to date:
1. Final drive exchanged for lower gearing
2. Ignition moved to battery compartment
3. DMC triple tree (easier steering)
4. Lower, wider bars
5. New brake lines (bar change and sidecar brake addition made this a good idea)
I stole Jay's idea and built a cart for holding the hack when fitting. Life is good.
(overview.jpg)
Attachments overview.jpg (3446KB - 4 downloads)
Posted 2/17/2017 7:01 AM (#92398 - in reply to #92391)
Subject: RE: DMC on a 1998 Moto Guzzi V11
2000200050010010010025
We used to fabricate these sidecar dollies 25 years ago and sell them for $99.00. Two heights, 13.5 for URAL and high cars and 7 1/2" for Velorex and lower cars.
The steel and labor are worth more than $99.00 these days.
Harbor Freight now has moving dollies for about $7.00.
jaydmc
Posted 2/17/2017 10:11 AM (#92403 - in reply to #92391)
Subject: Re: DMC on a 1998 Moto Guzzi V11
100050025
Not sure just what the actual question is. So far what you are doing looks good however you really do need to put the wheel on as you will align off of it, while in theory the axle is square to the frame, due to production tolerances it may be a bit off, not enough to see but enough to change alignment.
rtbain
Posted 2/17/2017 3:20 PM (#92406 - in reply to #92398)
Tried using a furniture dolly and scissor jacks. I prefer the dolly, more stable. The casters were the expensive part.
rtbain
Posted 2/17/2017 3:27 PM (#92407 - in reply to #92403)
Hey Jay, just the man to ask. Meant to post the question yesterday but got sidetracked.
My problem is the heim joint engagement in the rear mount. By my measurements only 3/8" engagement is possible with "proper" alignment. See pictures below.
The bike is squared up. The hack frame is squared up on the dolly. I do understand the wheel needs to be on for the alignment but wanted to sort out everything first. I also understand final adjustments should be made with the suspension normally loaded.
This is a bit frustrating as the images can only be added (to the best of my knowledge) after the text is posted. Please have a look at the attached photos and see if you can see where I am going wrong.
(rear.a.jpg)
Attachments rear.a.jpg (3540KB - 0 downloads)
rtbain
Posted 2/17/2017 3:33 PM (#92409 - in reply to #92391)
Another view of the rear mount.
(rear.jpg)
Attachments rear.jpg (3528KB - 0 downloads)
jaydmc
Posted 2/17/2017 3:34 PM (#92410 - in reply to #92391)
100050025
Normally the joints go straight on parallel to the ground. Try rotating the clamp. You may have to cut some off of the boss so that it does not hit the ground. We do make bosses with longer ends for the hiem joint if need be.
rtbain
Posted 2/17/2017 3:38 PM (#92412 - in reply to #92391)
The front mount is parallel with the ground.
(front.jpg)
Attachments front.jpg (3489KB - 0 downloads)
jaydmc
Posted 2/17/2017 3:38 PM (#92413 - in reply to #92391)
100050025
You might find it help full to go to our site and watch the second and third video's http://www.dmcsidecars.com/video/
This link also has some good photo's that might help you http://www.dmcsidecars.com/the-result-of-improper-sidecar-mounting-...
rtbain
Posted 2/17/2017 3:48 PM (#92414 - in reply to #92391)
I have seen the videos. They are well made and clear. Unfortunately I can be an idiot at times. Finally figured out the correct orientation thanks to your kind guidance. Photo below.
(rear.v2.jpg)
Attachments rear.v2.jpg (3609KB - 1 downloads)
rtbain
Posted 2/17/2017 3:59 PM (#92415 - in reply to #92391)
How much lead should be on the sidecar axle? The bike has been fitted with a DMC tree.
jaydmc
Posted 2/17/2017 4:02 PM (#92416 - in reply to #92391)
100050025
For street applications we recommend 10 - 15 % of the wheel base of the bike.
CCjon
Posted 2/17/2017 5:02 PM (#92417 - in reply to #92391)
Extreme Veteran
1001001002525
Easy to remember guide - Lining up the sidecar axle with the front of the rear tire will work out to just about the 10 - 15% rule that Jay mentioned.
rtbain
Posted 3/24/2017 6:43 PM (#92870 - in reply to #92391)
Everything mounted and test ride completed. The DMC tree made a huge difference in ease of steering.
(sophia.jpg)
Attachments sophia.jpg (838KB - 1 downloads)
rtbain
Posted 3/25/2017 8:39 AM (#92872 - in reply to #92391)
Does anyone have information on suspension set up? Looking for new springs to compensate for the added weight.
DRONE
Posted 3/26/2017 11:03 PM (#92880 - in reply to #92391)
Veteran
10010025
For the bike or for the car? If bike, fork springs or shock springs?
rtbain
Posted 3/27/2017 9:36 AM (#92883 - in reply to #92880)
It's the bike suspension. Looking to upgrade the fork and rear shocks.
IndSlim
Posted 3/27/2017 12:20 PM (#92889 - in reply to #92883)
Regular
252525
Check with Progressive Suspension.
rtbain
Posted 3/29/2017 9:43 AM (#92938 - in reply to #92889)
Progressive does not have direct kits for the EV. I am trying to find:
Spring dimensions and rate for the forks.
Spring dimensions and rate for the shocks.
SwampFox
Posted 3/29/2017 10:06 AM (#92939 - in reply to #92391)
10005001002525
Might check with Ikon Suspension USA. The former importer was very helpful re: replacement shocks for two of our rigs.
