Random quote: The Plan is to.... "Grin a lot and TRY not to make others Bleed
- (Added by: guzziguys-eml-tn)
SPROCKET RATIO 3.07 TO 2.82
Pillage
Posted 5/8/2017 11:29 AM (#93438)
Subject: SPROCKET RATIO 3.07 TO 2.82
I have a 1978 CB750F with a lightweight (200LBS) Cozy sidecar. Originally the 78 came with a 630 non O-ring chain and 14T/43T sprockets.
I'm converting to a 530 X-ring chain and the closest sprocket ratio I could get was a 17T/48T set, which was standard on this bike for many previous years.
Am I making a mistake? What I mean by that is do you think I will be adding undue stress to the engine and clutch by changing the ratio from 3.07 to 2.82 or 8.8%?
CCjon
Posted 5/8/2017 11:54 AM (#93440 - in reply to #93438)
Subject: Re: SPROCKET RATIO 3.07 TO 2.82
Extreme Veteran
1001001002525
Pillage,
Could depend on how strong the clutch is, is original or upgraded? How much weight do you plan on carrying in the sidecar.
Have you considered a 525 16T countersprocket? A 16/48 would give you a 3.00 ratio.
Pillage
Posted 5/8/2017 12:42 PM (#93441 - in reply to #93438)
The clutch is solid. 60% of the time I have only 70LBS of balast in the sidecar, 40% up to 200LBS (passenger & gear). I've had no problems going from an uphill stop. Although I did take a 300LBS passenger for a short ride recently and my machine was definitely stressed when starting uphill from a stop. I won't do that again, as I was also stressed knowingly overloading my precious bike & sidecar. I'm currently not able to ride a two wheeler, and having this sidecar has kept me on the road and very happy!
I have a brand new 530 x-ring chain (purchased for a bike I subsequently sold). I was looking for a cheap way out, by converting to 530, which is a common for 77-78 CB750F's. All other Gen 1 CB750's had 530 chains and between 2.7 to 2.8 sprocket ratios. I like your 16T suggestion and will try again to find one, before I install the 17T.
