Random quote: Indecision is the key to flexibility.
- (Added by: Reardan Tom)
Plastic part to join windscreens and sidecar cover
Roulemabosse
Posted 6/6/2017 9:35 AM (#93760)
Subject: Plastic part to join windscreens and sidecar cover
I own a Vetter Terraplane sidecar.
I need to find the part (or to adapt something) which joins the front windscreen and the side widescreen of the sidecar (see pictures attached).
I also would like to add a cover to ride under rain with my kid. Any picture or idea how to do it?
Thanks.
(DSC_0029.JPG)
(DSC_0031.JPG)
(DSC_0032.JPG)
Attachments DSC_0029.JPG (1609KB - 0 downloads)
Attachments DSC_0031.JPG (1744KB - 0 downloads)
Attachments DSC_0032.JPG (1762KB - 0 downloads)
IndSlim
Posted 6/6/2017 9:35 PM (#93767 - in reply to #93760)
Subject: Re: Plastic part to join windscreens and sidecar cover
Regular
252525
I can't help you with the parts, but I will share a tip: To keep the cracks in your windscreen from continuing to travel, drill a very small hole at the terminus of the crack.
Good luck.
Al Olme
Posted 6/6/2017 10:22 PM (#93768 - in reply to #93760)
Subject: RE: Plastic part to join windscreens and sidecar cover
10005001001002525
The picture looks like two pieces of "J channel" glued back to back. You might want to check out this...
https://www.mcmaster.com/#trim-molding/=17yilev
Scroll down to "trim for connecting panels" for a start but poke around, you might find something you like better.
Good luck!
OldSchool_IsCool
Posted 6/7/2017 1:42 PM (#93775 - in reply to #93768)
Extreme Veteran
1001001001002525
Or maybe search the web for anyone selling small quantities of H-channel.
This is just an example, I have no info on this company so I can't comment, positive or negative on them.
http://www.acmerubber.com/hchannel.htm
Roulemabosse
Posted 6/7/2017 4:31 PM (#93778 - in reply to #93760)
Thank you for your input, I will check that.
85shadow
Posted 6/7/2017 10:25 PM (#93782 - in reply to #93760)
Regular
2525
I have a Terraplane also ( a new acquisition ) it has aluminum channels, maybe shower door? I'll try to get a pic and post it.
(P1030019.JPG)
(P1030016.JPG)
Attachments P1030019.JPG (229KB - 0 downloads)
Attachments P1030016.JPG (253KB - 0 downloads)
ocpd44
Posted 7/6/2017 7:27 PM (#94061 - in reply to #93760)
25
You don't say where you live but, if you around water, take your car to a sailmaker or canvas shop. They'll be able to make and fit a soft top for your car.
Roulemabosse
Posted 7/10/2017 5:57 PM (#94103 - in reply to #93760)
