Random quote: ?Just because you can put a jigsaw puzzle of the Sistine Chapel together all by yourself, doesn?t make you Michelangelo?
Tubless Tire
guitarzan
Posted 6/13/2017 9:08 PM (#93837)
Subject: Tubless Tire
Hi,
I have a Terraplane sidecar and I have a question. It has the original rim on it and a tire with a inner-tube. I want to go with a tubeless tire but I cant do that with the original rim, right? What would I have to do to be able to run with a tubeless tire?
Thank you
Frank
OldSchool_IsCool
Posted 6/13/2017 9:26 PM (#93838 - in reply to #93837)
Subject: Re: Tubless Tire
Extreme Veteran
10010010010025
Put a tube in the tubeless tire. Works a treat!
85shadow
Posted 6/13/2017 9:29 PM (#93839 - in reply to #93837)
Regular
2525
You will need to change the rim to run tubeless, but keep in mind that most of the flat profile tires are tub-type.
guitarzan
Posted 6/13/2017 10:20 PM (#93840 - in reply to #93837)
I didn't know that most flat profile tires are tub-type. I was just thinking that it would be easier to repair a tubeless tire than one with a tube. I'll just run a tube tire.
Thank you
Frank
beezageezer
Posted 6/14/2017 3:15 PM (#93850 - in reply to #93837)
maybe this kit?
http://www.ebay.com/itm/EXCEL-H-type-Spoke-Wheel-Tubeless-Kit-18-19...
