Random quote: life is tough but its even tougher if your stupid(USMC quote)
- (Added by: gargantua)
CHEAP REVERSE GEAR MOTOR
THEMARCO
Posted 9/1/2017 11:08 PM (#94924)
Subject: CHEAP REVERSE GEAR MOTOR
CHECK EBAY OR AMAZON FOR " ELECTRIC TRAILER MOVER" APPROX $200. I ORDERED ONE. HAVEN"T RECEIVED IT YET. WILL TAKE SOME INGENUITY TO MOUNT.
CHEAP LIFESAVER!!
jaydmc
Posted 9/2/2017 12:37 PM (#94929 - in reply to #94924)
Subject: Re: CHEAP REVERSE GEAR MOTOR
1000500100
We tried one of these once, just far to slow, was "OK" at best once we did away with all of the gear reduction.
We have also used winch motors for reverse.
THEMARCO
Posted 9/2/2017 10:44 PM (#94935 - in reply to #94929)
i'll let you know. I hope it beats making my wife trying to push 1,000 lbs for me.
THEMARCO
Posted 9/2/2017 11:11 PM (#94938 - in reply to #94929)
6-7 meters a minute. good use for backing out of garage or a parking spot, very short distance only. not trying to set land speed record. going to mount between bike and tub. will pivot unit up when not using. going to use unistrut and spring nuts mounted between top of frame and bottom of tub will see very little mounting.....
hey 200 bucks???
Woodyambison
Posted 9/25/2017 2:33 PM (#95181 - in reply to #94938)
Regular
2525
Hey let us know how it works out and pictures if you can.
Thank you.
THEMARCO
Posted 9/25/2017 8:29 PM (#95184 - in reply to #95181)
GAVE UP FOR NOW. WILL WORK ON IT OVER THE WINTER. IS GOING TO TAKE SOME CREATIVE MOUNTING. PROBABLY HAVE TO WELD PLATE ON SIDECAR FRAME.
TRIED BOLTS AND UNISTRUT. MOTOR HAS TOO MUCH TORQUE AND TWISTS MOUNTING. IT WILL WORK BUT A STEEL PLATE WITH GUSSETS WILL HAVE TO BE WELDED ON.
THE MARCO.
