Random quote: my Wife wondered why I took so long at the store...I told her i had some SDF.....Sidecar Delay Factor.
- (Added by: Modelflyered)
Heat inside car
LMR
Posted 1/23/2018 2:44 PM (#96141)
Subject: Heat inside car
25
I am looking at the Hannigan GTL sidecar or the Astro 2+2. I am wondering how hot it may get in the tub while traveling in the heat. My concern would be for my little lady, a neo mastiff.
taco
Posted 1/23/2018 3:32 PM (#96142 - in reply to #96141)
Subject: RE: Heat inside car
25
My wife said it got pretty hot, so I added a air cope to the hood.
(38.JPG)
Attachments 38.JPG (97KB - 2 downloads)
LMR
Posted 1/23/2018 4:01 PM (#96143 - in reply to #96141)
Subject: Re: Heat inside car
25
So it didn’t come with a vent ?
taco
Posted 1/23/2018 9:56 PM (#96144 - in reply to #96143)
25
It had a small vent on the left side but not big enough for much air to get in.
ocpd44
Posted 2/11/2018 3:01 PM (#96291 - in reply to #96141)
25
We were concerned about that as well, particularly since we traverse the desert several times a year. We had the "factory" air installed in our Hannigan GTL. It is an ice cooled condenser system, not a swamp cooler, and it seems to work well. I say seems to because we haven't had warm enough days to be able to actually use it.
Regards,
Jeff
CCjon
Posted 2/11/2018 3:12 PM (#96292 - in reply to #96291)
Extreme Veteran
100100100252525
Many sidecars have circular floor vent that they can open and close as needed.
Here is a $40 vent on eBay
https://www.ebay.com/itm/Sidecar-Air-Vent-4-Floor-Mount-Velorex-Cozy...
VLAD
Posted 2/11/2018 4:28 PM (#96297 - in reply to #96292)
Extreme Veteran
10010010010025
No need to pay $40. For $10 you can do similar from black sewer pipes from hardware store.
An ice cooled condenser system works well. Just add ice every 2-3 hrs.
Edited by VLAD 2/11/2018 4:30 PM
ocpd44
Posted 2/11/2018 5:30 PM (#96298 - in reply to #96292)
25
CCjon - 2/12/2018 12:12 PM
After reading the entire description, I think I'd pass on that. Opening the vent would bring heat up from the asphalt quite likely making it warmer inside. Most of Hannigan's and Champions sidecar have a forward facing vent that allows air in from the front. I'll stick with our AC.
Jeff
Gecker
Posted 2/11/2018 9:46 PM (#96299 - in reply to #96292)
CCjon - 2/11/2018 3:12 PM
https://www.ebay.com/itm/Sidecar-Air-Vent-4-Floor-Mount-Velorex-Cozy-Inder-Eagle-CSC-Harley-Motorcycle/322752329858?hash=item4b2589b882:g:eoQAAMXQqC9SMfQ0&vxp=mtr
That looks pretty good vent. We'll be working on the side car right after we finished installing the new tires and atv plows on the Kawi Brute. We'll take a look at that floor vent.
bentleyssq
Posted 2/23/2018 1:05 PM (#96446 - in reply to #96141)
Regular
252525
I have a Hannigan Astro 2+2 and I live here in Florda. They get pretty “toasty” in the warm weather, I am finishing up the DIY install of ice cooled condenser unit and will try to do a write up with pics and parts I am using.
ocpd44
Posted 2/23/2018 8:26 PM (#96451 - in reply to #96446)
25
bentleyssq - 2/24/2018 10:05 AM
The stock Hannigan AC is a Water condenser system. I knew my wife would need it so we had it installed as an option.
Jeff
