Random quote: "The more corrupt the state, the more numerous the laws."
Spacer for my SideCar Tire Rim Wheel Assembly
BestBuddy
Posted 4/3/2005 8:41 PM (#7134)
Subject: Spacer for my SideCar Tire Rim Wheel Assembly
I have a problem and want to see if such an item is available and where someone can purchase it.
I need to move the tire rim with the tire for my SideCar, out and to the right by either a ¼” or 5/16” or 3/8” of an inch. Presently the tire rim with the balancing lead weight is hitting and rubbing on the bleeding nut of my Bimbo brake assembly.
The steel or aluminum spacer that I need should be 5-1/2 inches in diameter with an inside diameter of 2-1/2 inches. In addition it should have four (4) ½ inch diameter holes to go over the tire rim mounting pattern which is four inch diameter with holes at 12 o’clock, 3 o’clock, 6 o’clock and 9 o’clock. Each hole should be approximately 17/32 of an inch.
Can anyone out there, tell me where I can get this spacer or does it have to be made SPECIAL
Awaiting your replies
Best Buddy
claude #3563
Posted 4/4/2005 6:01 AM (#7138 - in reply to #7134)
Subject: RE: Spacer for my SideCar Tire Rim Wheel Assembly
2000100100100100252525
Buddy,
In case you haven't noticed there has been numerous reposes to your question at SCT.
