Random quote: It is difficult to get a man to understand something when his salary depends upon his not understanding it. - Upton Sinclair
Mounting Ural on 1975 CB750
Posted 7/2/2004 6:40 PM (#3989)
Subject: Mounting Ural on 1975 CB750
I have just gotten a Ural to replace the Velorex previously installed on my 1975 CB 750 (the Velorex was mangled by a clueless automobile driver.) The Ural has the usual ball mounts on the bottom and the front lower mount is fixed. I have the Dauntless center stand mount still in place from previous installation. I am wondering if anyone has had any luck mounting the 30mm ball mounts on a CB750 frame amd utilizing either of the original lower Ural mounts? Any advice is most appreciated, I finally got the sidecar I always wanted and I would like to achieve the cleanest installation possible.
Posted 7/2/2004 7:36 PM (#3990 - in reply to #3989)
Subject: RE: Mounting Ural on 1975 CB750
2000200050010010010025
The ball and collet mounts can be used if preferred with a bit of fabrication and welding.
I cut the front tube close to the frame gusset and rotate the collet to get the car mounted back a little farther, then reweld it in that position.
For the front a small sub-frame can be fabricated out of 1"x1"x.120" square tubing with the ball mounted on the end. This sub-frame can be attached to the front downtubes with u-bolts equalizing the stress to both sides of the frame. The upper front strut mounts with a U-clamp eye bolt.
I sometimes weld a triangular 3/16" plate with the rear ball attached where the tubes meet, for the lower rear mount. The rear sidecar mount can be split and extended with a piece of 1"x2"x.120" square tubing of the proper length. The upper strut mounts with a U-clamp eye bolt.
JayDauntless
Posted 7/6/2004 12:50 PM (#4028 - in reply to #3989)
Bummer about your Velorex.
If your center stand mount has the eye threaded into it (as we normaly make them for the CB 750) then we can supply you with a 30mm ball to thread into the same hole.
Jay Giese
Dauntless Motors Corporation
